Now then boys and girls...I spent a lot of time and money last year failing to make a concentric coil for my uMaxII copy. In the end I picked up an unknown one on Ebay for £5.00 and it works quite well but at 13.8KHz.I have spent a long time gathering info, reading it etc. Of course none of it tells you what doesn't work and, as I found out today, it is all a bit trite "you may have to add or remove a turn..." yeah right!!!
One article suggests that the buck coil can be wound on its own and then taped to the Rx coil; it was the basis of ALL my work last year, and four more goes this year. Well please excuse me, but Bollocks! NO! NO! NO!
I used varnish to hold my windings - the result was very badly reduced frequencies.
I studied, I wrote a spreadsheet, did the math, calculated the turns etc. Crap.
So then I built a whole new jig (fresh start etc). I built the coils as per another article (well almost). The article used foam board sandwiches, I was going to but I ate them. Taste like plastic, like British Rail sandwiches.
So I made a Tx coil of 8" and wound it to exactly 10.15KHz.
I made an Rx coil of 4" and wound it to exactly 9.7KHz.
I wound a buck coil (1:4 ratio) directly on top of the Rx coil.
No tape, glue or anything else. Couldn't adjust.
Crap.
I wound another buck coil that I knew had too many turns and carefully began taking them off, watching the scope.
2.5mV NULL
So far this is all on the jig.
Hooked up the pcb, on the bench etc. I am seeing a nickel size coin at over 30cm (in air)
Next, as per Guru instructions, Superglue the windings.
Test. Crap.
Frequencies completely ruined. 7KHz on Tx.
Rermove buck winding, 6.8KHz on Tx.
So, the glue (like the varnish) has stuffed it.
Now I must conjecture or maybe guess, I guess the glue has caused some capacitance in the (tight) windings and detuned it because I see no way for the inductance to change; n turns of n guage = n uH whatever - it is a law and ye cannae change the laws of science, Jim.
I removed a fair few windings to bring the Tx up to 9.7Khz (I have a cunning plan).
I rewind the buck excessivley and remove turns until I get a 3mV Null.
The Tx Freq is now 10.1KHz (the buck coil upped it a bit, my plan worked).
We can be sure that the Rx coil has changed but it is under the buck and it's staying there.
I know that when the shield is fitted the NULL will drop a little more. God knows what the expoxy resin will do to it.
I am back to 30cm + range.
I will post more after the next bit.
BTW, I bought a Tesoro coil cover, tipped it upside down and it is the shell top. I will fit a plastic disc to seal it.
