Originally posted by sinclairuser
Another PI coil shield method.
I wonder if the cross section shorted section is what is causing so many people to have trouble with foil shielding ?Cut the Scotch 24 mesh 1.18 inches wide. Wrap around the coil but make sure that the wire mesh does not touch and form a cross section shorted section that will cause eddy currents to form.
I am thinking maybe a thin copper tape spiral wind around coil but winds not touching ?
The ultimate shield test is to make a small, unshielded, fast, test coil to see if various length samples of the shield are detected. Cut a piece 5mm, 10mm, 20mm, 50mm and 100mm long and mount on a piece of cardboard and wave under the coil. The cardboard prevents your hand from being detected on an unshielded coil. Typically, when you want to use delays below about 10us you will need to use a thin coil solid wire or very thin stranded coil wire (about AWG32 stranding). Tinned stranded wire is better than silver coated wire as silver is too conductive between strands and looks more like a small target.Originally posted by 6666 View PostI wonder if the cross section shorted section is what is causing so many people to have trouble with foil shielding ?
http://www.ebay.com.au/itm/New-Arriv...item2333329955
I hope this helps?
Joseph Rogowski
Just tested a 2 inch or 50mm strip with PI, and not detected, however the WHOLE roll could be.Originally posted by 6666 View PostI wonder if the cross section shorted section is what is causing so many people to have trouble with foil shielding ?
more to come.
