How is a Grid Dip Meter used to measure a detector coil?
  • How is a Grid Dip Meter used to measure a detector coil?
    Hello would some one please tell me how I can use a Dip Meter / Grid Dip oscillator to measure the frequency of a home made detector coil. I ask because I want to try building some coils that have an included damping resistor and so have a selection of coil sizes, that can be plugged directly into my Surf PI 1.2 to give flexibility. thank you.
    With PI, Remove damping R and feed line then dip meter against coil. look around 1.1 to 1.4 megs.
      Thank you, but in order to keep the coil water proof I have been winding coils (coated cables) with a feed line left on, if I lay it out straight, do you think that would be OK, or perhaps feed it through a ferrite core. again, thank you.
        I am not sure what you are asking about the ferrite,, but it sounds like your coils are already sealed up, I can remove all the feedlines off my coils and get my Kenwood gdo close the coil, while I have not tried it you could try putting a small coil of a couple of turns on the end of the feedline and see what the gdo tells you
          Yes, sorry to confuse you, when winding my coils I leave 3ft of wire on each end and twist them. so there are no joints in the coil housing for water ingress, I just thought a ferrite slipped over the feed cable down to the coil would stop any interference from the feed cable. I do though understand how to use the Dip meter now, thank you appreciated. Ken
            ok on the lead wire, the lead wire will reduce the res freq of the pi coil, just place the gdo coil near the pi coil and test.
              OK, thanks again
                When I add a twisted pair feedline (which has about 50pf of capacitance) to my basket weave coil the res freq drops from about 1.4 megs to about 1.3 megs.
                  you may try shorting the coil at the lead. then offer up the GDO
                    Thank you for that.
                      If your coil is mounted on the detector and you had a scope you could see the small ring after the Tx an that would be the self resonance of the coil/lead combo
                        Yes thank you. I have organised a dip meter for my testing. Grateful.
