Help shielding is driving me mad
I have built a new 27cm DD coil
Made the shield with graphite and yacht varnish. One side came out at 100 ohms per square in the other is 500
no mater how I connect the shield I can not make the coil stable.
Even touching the coil cable makes the detector sound of even if its near the control box.
so I disconnected the shield from the cable and and placed a separate wire to the connector. A slight touch of the original data cable still make the detector sound off as does touching anywhere on the coil underneath or on top makes no difference.
touching the new ground wire and the detector does not sound even if its the bare wire
A factory coil works fine
Tried USB2 cable and high quality microphone cable.
tried top and bottom shield only to ground pin on connector
tried top and bottom shield plus RX earth to ground pin on connector
on the connector side I have tried just the ground pin and the ground pin and connector shell
Must be missing something simple
Other than that the coil is working great as I have nearly twice the detection range on a silver cut half over the factory 8"
