Hopefully this is a quick question - Ive built two round 'bundled' coils for my Surf PI - a 10" and a 6", both measure a fraction under 300uH (270uH and 280uH resp.) and about 1.4 ohm. Ive then found what I think is about right for the damping resistor using a potentiometer. The 10" coil measures 427 ohm and the 6" 446 ohm,
How accurate do I really need to be? The reason I ask is that 430 ohm is a standard 5% series value, the next up being 470 ohm. Will standard series values be ok or should I make up a more accurate resistance from a few selected standard values?
