I need to build a Barracuda coil.
I already have some AWG 26 teflon stranded wire but was not sure if the using thicker wire would not be better.
I decided to calculate current numbers for different gauge wire. The key number I was looking for was instant coil current 100uS after switching it on. (Max current on the end of the sample)
Coil diameter 255mm; inductance 440uH ; 29 loops
wire length 78 feet
power 12V
coil ON time 100uS
max amps = 12 V / (resistance + 0.5ohm ) mosfet in line correction
[awg] [wire resistance ohms] [max amps] [100uS amps]
30 8.2 1.37 1.157
28 5.16 1.77 1.22
26 3.25 3.2 1.67
24 2.04 4.72 1.75
22 1.28 6.74 1.7
20 0.807 9.23 1.53
the numbers are for solid wire, stranded is probably 10% more resistive this was not taken into account.
it looks that wires 26 to 22 would be fine with 24 being the best.
here is the instant current calculator
Anyone have any empirical test results for Barracuda PI coils?
I have DD housing so it will be a regular "bunch" circular coil.
wire length 78 feet
power 12V
coil ON time 100uS
30 8.2 1.37 1.157
28 5.16 1.77 1.22
26 3.25 3.2 1.67
24 2.04 4.72 1.75
22 1.28 6.74 1.7
20 0.807 9.23 1.53
