Originally posted by Geo
DOD coil for TDI
Yes, one 680R at Rx input. Now i will try one resistor for every D winding and will try for a better null.
Problem is that i"ll have free time after one week (maybe).
When i destroy the null of one D (not everyone D) then i have big signal without this "crack". Maybe bad balance between two D and O coil.
New coil... new problems!!!
. As we say here at Greece ""new donkey new walked""
You need to put a damping resistor on the TX coil and on each RX coil.Originally posted by Geo View PostYes, one 680R at Rx input. Now i will try one resistor for every D winding and will try for a better null.
Then you can try to null the 2 RX coils.
For a perfect null you need to adjust the phases of the two RX coils, shifting the phase of one coil, the match the other coil.
Finally i finished the OOO coil and tried it at field. Tx coil has 30cm diameter and Rx coils have 24cm diameter.
Results are good, so i have about 10% more depth than the 12" original coil.
Also i have the same depth with GB=on or GB=off. This is because the coil is very quite and i can work with GB=on and potentiometer at "11". Ground at field is so mineralised that with 12" coil and Gb=on i have gound balance at position "6". The only basic problem is the big dimentions. Maybe i must give another try at DOD coil. Also i must give more gain at TDI because is so quite.
Thanks for report Geo. It is worth to give OOO a second try.Originally posted by Geo View Post
Balancing principle are the same with OOO, but somewhat more delicate, cause of shape.
Dimensions of OOO shape outcome problematic in practical hunting.
