I got problem with my surf pi..its working great with unshielded coil but it doesnt work on of my several barracuda shielded coil.. It keep on sounding and cannot able to detect.. Any idea why??
Surf pi shield or other problem?
Does your coil start to work at maximum sample delay? If so it is 'slower' than your other coil that does work.
Secondly have you tried to set critical damping on the coil that does not work? It could be that the two coils are different enough that the damping only works for one coil and needs adjustment.
Dan
Thanks Dan! Yes maybe it us slower coil problem..i will check it out..about damping resistor yes i already set critical damping but the same problem exist.Originally posted by baum7154 View PostDoes your coil start to work at maximum sample delay? If so it is 'slower' than your other coil that does work.
Dan
