Originally posted by godigit1
Hi Godigit,
Did you get your micrometer from Harbor Freight? They do have some pretty good deals. Just curious if you have checked its accuracy against a feeler gauge because sometimes they need to be zero adjusted by rotating their barrel scale. Just a thought cause I've never seen a .005" sidewall midpoint.
Regarding the critical damping, it is determined by inductance and capacitance or in other words Self Resonant Frequency of the coil, feed line, and detector. The formula PI X SRF X uh = Damping Resistance. This will get you in the ball park for the coil/ feed only. What all this says is that even though three 300uh coils made with different materials or shapes will not use the same damping resistor. So you should damp each separately to optimize performance.
Good Luck,
Dan
