White TDI Dual Field Coil Din Plug Wiring Diagram
  • White TDI Dual Field Coil Din Plug Wiring Diagram
    I built a minipulse plus rev D and I am using my own coils and works fine, I came across a TDI dual field coil that I was going to play around with does anybody know the pin assignments for this coil or how I can determine? Thanks I am rather new to electronics which is pretty obvious.
    You only have two wire you need. Open the Connector. All should be easy to see.
      Not so easy. The coil connector includes a jumper for 2 of the pins, because the TDI is designed to accept either mono or DD coils. Somewhere on these forums there is a diagram, probably several.
          Thanks everyone for the help.
