I'm trying to keep a Red Heat Lightning 4 alive, the original 8.5DD coil is faulty, it faults on mechanical impact and slight pressure.
Original coil is 4 pin
Original coil cable:
Pin1-Pin2 (red-black, Rx?) = 28.2 Ohm
Pin3-Pin4 (white-green, Tx) = 30.6 Ohm
I've found induction data for concentric 9'' coil on this forum:
1-2(Rx?)=5.6mH; 3-4(Tx?)=5.4mH
Drain wire is soldered to Pin4 at the control box at attached to ferrite screen in the coil.
It looks like Rx and Tx are wound with the same wire, 0.4mm it seems.
What could you say about this coil? Tx Rx small resistance difference is ok?
Concentric and DD induction data is always the same? Can I use that data for reference?
Is it possible to tell which one is Rx and Tx?
I will try to make a OO coil (a la Nexus) with the same winding diameter.
FOMA's method seems ok to me
Although this method describes how to measure using a generator for the case when you only have a coil, without the control box. I would use a frequency measurement from detector itself, not from the generator. Is this achievable by reading from the pins?
Please help to extend the life of this rare beast.
