New hobby pi detector Coil
    Thanks again. After reading the instructions i get the answer. Here it is(thecitation) for those who may come with the same idea:
    Separately, we want to draw your attention to the fact that the struggle for reducing interturn capacitance is not justified in each sensor. For example, we sometimes ask - and it would be nice to do "deep basketware sensor" size or 1x1m 2x2m . The answer - it is absolutely unjustified. The fact is that when working with deep probes instrument specially configured to work with high-latency processing. This is to reduce the sensitivity to the soil and shallow targets. Therefore, there is no reason to fight for the reduction in the duration of the transition process, as well as delay its processing significantly exceeds.
      seems you have abrakadabra (mishmash) in your head. a deeper with ramka coil 1x1m working on big SAMPLE DELAY
      while you mean a basket coil in relation to small SAMPLE DELAY for gold nugget seeking.
      you must SPLIT the ONE matter in TWO then you will get right answer.
        LoL, the mismatch is not in my head but in the way translation is done on english. After your clarification it sounds a bit better but still. Probably if i read the original Russian version i'll get it clear as what you see is what i citate from the web. Will try to do so and translate it properly as it is confusing.
