I have no experience of nugget-hunting, so this is just a curiosity question:
What sort of size/weight nugget would you viably expect could be detected at 24" depth? 15mm diameter? Golf-ball size? Fist-size?
I'm aware nuggets aren't spherical, and have inclusions of rock and quartz etc, so they may be harder to find than their apparent size would suggest.
Have you (Green) done any buried or air tests with your available coils, with real or 'simulated' nuggets?
detection depth
If you specify the time constant (TC) of the target, you can calculate the best PI parameters to optimize the potential detection of that target. Here is an example.Originally posted by green View PostTarget, 20 inches deep. Best coil size, 40 inch diameter. Target just detectable with the 40 inch coil. How to approximate detection depth with a 20 inch diameter coil?
Keep inductance and current profile the same.
Let us assume that the target has a 5uS TC. We would need a TX pulse at least 5 times longer than the target TC or 25 uS. The full stimulation of that target would require a coil with a coil discharge TC of one fifth the target TC or 1 uS. That means that we need a coil of 300 uH that has a 300 ohms effective damping resistance value. This effective value includes the input resistor to the first op amp stage which clamps the input resistor in parallel with the damping resistor during the flyback pules down to about 0.6V. If you set the delay to 10 uS your maximum target signal will be 2 TCs or about 86.5 percent lower than the maximum target induced signal.
Knowing the target TC can help you reverse engineer a coil resistance, inductance, effective damping value along with the proper TX and RX parameters for that target. Since target TCs are unknown, we tend to cluster our coil sizes/types and PI parameters for certain classes of targets such as coins in a beach or small gold nuggets in a stream bed or small nuggets in mineralized soil.
There is a limit to how much power you can pump into a target area as the doubling of detection distance in theory needs 64 times more power. That is 2 to the third power to stimulate the target and 2 to the third power for the return trip of the target eddies back to the coil which adds up to 2 to the sixth power or 64. Then there is minimizing noise in the RX circuit when using the highest gain to maximize sensitivity. Here is where Eric Foster integrated many RX pulses to lower the noise level much like what is used in Lock-in amplifiers.
I hope this helps?
Joseph J. Rogowski
Nice fantasy. I would certainly not allow you to select the coil, I would do it myself. The selection of the coil would depend on the specific circumstances, which your fantasy didn't define. In any case all it is, is a fantasy. People who do cache locating put some work into learning what's involved and they get their hands dirty in the process.Originally posted by green View PostIf I buried a gold nugget at 24 inches deep and you could have it if you could detect it. You select the PI detector and have a choice of 5 coils(all have the same inductance, resistance and resonance) 8, 16, 24, 30, 40 inch diameter. Would you allow me to select the coil for you or would you rather select it and if so which coil would you select?
If I buried a gold nugget at 24 inches deep and you could have it if you could detect it. You select the PI detector and have a choice of 5 coils(all have the same inductance, resistance and resonance) 8, 16, 24, 30, 40 inch diameter. Would you allow me to select the coil for you or would you rather select it and if so which coil would you select?Originally posted by Dave J. View PostGreen, everything matters. Ground conditions. Electrical interference. Retune speed. Electrical properties of the target. How the metal detector is ground balanced. Whether or not there are other nearby esp. shallower targets. How the machine processes signals. How the user has the controls of the machine set. How the user sweeps the ground. Whether or not you sweep the thing over the target. Whether or not at that moment you're paying attention. Whether or not you're willing to dig a sound that doesn't jump out at you and yell HERE I AM, DIG ME! All those things interact with the issue of searchcoil diameter.
There are no straight answers your question. The place to begin is not searchcoil diameter, but to understand cache locating.
http://www.geotech1.com/forums/showt...438#post228438 Graph with text. Curves are for constant number of turns not coil inductance.Originally posted by Skippy View PostYes, yes, yes, I know that, that's why I said I wasn't going to post the graph because I couldn't find the accompanying text. But as I didn't know whether I was looking for a .txt file, or a .png, or a .jpg, or .html, it makes it bloody hard to find, OK.
So just the graph will have to do for now.
OK, found it, it was an .mhtml file, never ocurred to check for them. BUT, I can't attach such a file ffs. I will have to think.....this is bloody frustrating, even a tiny text file won't attach, at just 21 K I'm told it's too f-ing big. Come on George, can the limit be increased please.
Retry:
Retry:Attached Files
Re: Dave's "Understanding cache locating" comment. I get the impression no-one does it, or they don't know anything about it. I started a thread on Dankowski's Forum about it last year, as I've been trying my hand at it, and thought the experienced folk there would have some wisdom to pass on. Zip Nul Nada Sweet.Fanny.Adams. Not one reply...oh well, I tried.
Back to Erics graphs: Here's the graph, I can't find the original explanation.
This is for PI machines, for circular mono coils, not accounting for ground effects.
Basically each solid curve is for one particular size target. Bigger targets have a higher-up curve. So take the point where the 40" coil just detects the large target 20" away. Now move left down that line, and when the coil-size reads 20", you will see a target depth of 17.5", as I quoted earlier.
I have never tested out this data, I'm not a PI guy, and how circular mono-coils compare to elliptic DD's is not my specialised subject : )Attached Files
Originally posted by green View PostCarl had a thread detecting a cache at 24 inches awhile back. Been awhile since I read it, don't remember anything detecting it. Assume PI detector with GEB(300uH coil, 1 ohm resistance). If you were to wind one coil to detect it, what diameter would you wind? Would it matter if the ground was mild or severe? Why does it matter what the target is if it's buried at 24 inches? I agree a 8 inch diameter could detect it if it is large enough but what diameter coil has the best chance of detecting it?
Quote:"Why does it matter what the target is if it's buried at 24 inches?"
Because: one 'solid' target (fist-sized nugget, horse-shoe, plough blade, metal box....) behaves in a significantly different way to a collection of smaller objects (stoneware jar full of Roman bronze coins, canvas bag full of stolen jewellery...). The latter scenario appears to most detectors as just the top layer of objects, and there's virtually no electrical connectivity between the items, so they don't 'join together' to look larger than their individual sizes.
[and for VLF purposes, the use of low-frequency machines doesn't help. If the coins are '8KHz coins', a big load of them is still probably best found with an '8KHz detector'. So the ground pick-up is higher (than, say, a 2KHz machine) limiting depth.]
Regarding the 24" cache, I believe that several machines have successfully detected Gary's (garysdetecting) original cache in Oxfordshire...large-coil Deus being one, and 12KHz freq, too, if I recall correctly.
Carl had a thread detecting a cache at 24 inches awhile back. Been awhile since I read it, don't remember anything detecting it. Assume PI detector with GEB(300uH coil, 1 ohm resistance). If you were to wind one coil to detect it, what diameter would you wind? Would it matter if the ground was mild or severe?Originally posted by Dave J. View PostFor a target of a given diameter, if you're thinking only of relative voltage induced in the receiver, it's a fairly straightforward (when you know how) axial air coupling calculation. However a target that's "just detectable" is most often limited by a number of factors other than mere voltage induced in the receiver. Also your question as you worded it doesn't make sense: "best coil size 40 inch diameter, target just detectable" means that any other size searchcoil won't detect that target.
So, in the real world your question has no straight answer. The non-straight answer is that if a searchcoil of a given radius has a weak response on a particular target buried at a depth equal to that of the coil radius, an electrically equivalent searchcoil half that radius will kinda sorta more or less usually give a better response. Your mileage may differ.
[EDIT] now the question about a cache 2 feet deep, what size searchcoil will be best. There is no straight answer especially since there is no "given" regarding the effective diameter of the cache or what size of searchcoil is known to detect it. You might do fine with an 8 inch searchcoil and not need "best".
Presumably your 40" coil figure comes from the not-that-well-known data available online, particularly the graphs drawn by Eric Foster? The ones with the semi-circular curves?
Based on them, it would appear that a 41" coil or a 39" would be too big/small.
I'll dig out my copies of those graphs and report back later.
Update: That was easy, found the graph, can't locate the instructions, yet ....but:
Target depth with 20" coil will be 17.5"
I'll add the graph later when I find the 'manual'.
Are we talking of something like a buried ammo box made of metal
Large gold bars
Or individual coins.
Mineralized ground.
Still too many variables.
A PI. If a cache was buried 24 inches deep. What would be the best diameter coil to detect it? What would be the smallest diameter coil that would make sense to try?Originally posted by Koala View PostAre we talking pi or vlf
Depends a lot on the target size.
a small target on its edge is deeper with a smaller coil.
big coils are only deeper on bigger target.
