Been upgrading the old PI's.
  • Been upgrading the old PI's.
    Hi all,
    I am working on an old coil design to kill the totally overpriced GPZ.
    With the series of relative cheap SD/GP/GPX detectors.
    And with the QED.
    The old detectors will kill the new GPZ.
    Will kill every PI detector.
    We will see a new generation of PI coils soon.
    Eagerly awaiting, go Aziz, go!
      I hope you are successful Aziz. There are many variables to play with. I have been very impressed with my Coiltek 11DD on my SMpro, and strangely a .25mm enamelled wound in a hacksaw slot around a plywood 10x5 on my Baracuda...not quite as sensitive as my GMT E-series on small gold, but getting close.
      Looking forward to your developments.
        I will open up all the old gold fields again. The GPX-5000 is becoming a GPZ-Killer! Earlier models too. And will operate on extremely mineralized grounds.
          Probably it would be nice to adapt Chance PI (PI detector with discrimination)
          to accept your TX/RX coil?:
          http://crazy-tech.net/index.php?rout...&product_id=67
            Hi WM6, let me see the schematics and I can tell you, whether it is possible. Aziz
              I love my White's TDI SL, hope your new coil will give it some more depth!
                i have a Chance PI machine laying about collecting dust. i don't even have a coil for it. i bought it a wile back and have never used it.
                  http://chomikuj.pl/dantech/2nd+Chanc...5664598399.gif
                  Recently discussed on forum:
                  http://www.geotech1.com/forums/showt...-2nd-Chance-PI
                    Hi WM6,
                    yes, it is quite easy to do. But I doubt, that Chance-PI cold handle high ground mineralization. The detector won't profit from the benefits of the new coil. Except for pin-pointing.
                    The new coil is destined for extreme ground mineralization for gold fields.
                    Cheers,
                      same here built it 12 months ago it took so long to get all the parts bought an ATX But would like to build my own coil too
                        Need a waterproof coil for my gp extreme. It is awesome at the beach!
                          So, anything new with this???
                            I am getting a solid 2"+ more depth out of my Elite 14" round mono on nuggets in mild to medium ground, as compared to a 12x15 commander stock coil. That flat wire tech is good stuff. However my 14" round elite bottoms out at 13" on a 1.3 grammer, I need a coil that can hit 1.3-2 grammers at 15"-16" like the GPZ does. Maybe the 18" coiltek Elite coil could do it, not sure.
