xr-71 sniffer powerscan coil
  • #46
    Or you could try bigger fuse or bridging the fuse, just to see what burns/blows up or gets hot. Then you'd know where short is.
    • #47
      hello everyone, I have a problem with my Sniffer xr71, I made a coil 1 x 1 meter / 0.65 mm / 10 turns .the device sounds in all places when I put the coil on the ground , and it didn't detect the gold only the iron ?
      • #48
        you have to keep the coil on 5-10 cm distancy from ground keeping that more less constant.
        why you put a coil on ground? do you need to sleep?
        • #49
          is these parameter correct ( coil 1 x 1 meter / 0.65 mm / 10 turns ) ???
