shielding concentric
kt315 there is no attack .. it is just the answer to your tone and your way to get me high.
I have already
made the mix wood glue with graphite ..resultat very bad..tout the
powders of graphite do not have the same granulometry .. which plays on
the conductivity.
My initial question, in this case, what would you do .....?
what is the best resistivity for a shield .... on the forum there are all the values .. from 50 ohm to 2k .....? then does anyone have the answer?
1.5Kohm per centimeter is what you want. https://www.youtube.com/watch?v=XnrStRklcUQ
look from 3.00 minutes where he says 1.5kohm per centimeter.
Originally posted by lamoiz View Postmy first test with white wood glue and graphite gave 1.5k per cm. this was a failure. suddenly I do not understand what ohmic value I must take into account ... 20 ... 500 .... 1.5k .... ???
I was wrong about 1.5kohm it seems, very wrong. It seems you have to get the resistance down to around 500ohms by adding more graphite to mixture( the lower the resistance, the better). This video I found is very good at explaining it all. And he even explains what he did in great detail with his coil. https://www.youtube.com/watch?v=QrG_sXSybM4
Here the same guy mixes his graphite powder and shows you how. Very interesting. https://www.youtube.com/watch?v=SqM6eWwLIUs
And finally excellent video, very informative. Interesting how the outside of coil housing is shielded. https://www.youtube.com/watch?v=RtA1iVOBquA
Good evening
after manufacturing the coil holder and graphite paint from the bottom, the resistance is 400 to 1.5k end to end.
I decided to test in the wet grass .. just to see .... there is a multitude of false signals ...... more the coil reacts to the slightest vibration ...... I am really disappointed ....
ok it is not yet the resin that will surround the windings .... ok the shielding is not instalé .... but on my work plan, it ad excelentes discrimination .. selectivity and great distance of detection.1 eur at 30 cm ... gold ring at 20 cm
I do not know what to do for this shield. does anyone have an idea ??
thank you..
