ohm reading
  • ohm reading
    Need pin out ohm reading for the fisher f75 11" dd coil
    I'm pretty sure the full L & R info are stated in another thread on here, but nevertheless:
    Pin1 - Pin2 : R = 38 Ohms
    Pin3 - Pin4 : R = 2.4 Ohms
    Pin5 is connected to the screen/shield, and none of the other pins.
      Presumably your question is related to your earlier thread on the subject of F75 & T2 coils?
      It would've made sense to add your question onto that thread, rather than starting another thread.
      I don't know if you have an inductance meter, but the F75 11" x 7" L readings are:
      Pin1,2 : L = 6.95 millihenry (this is the receive coil)
      Pin3,4 : L = 690 microhenry (the transmit coil)
        I have lost coil ohm information. What sparked me to ask was I recently purchase the ARC Pro version of the F75. I noticed the machine would false if I move the detector quickly or rather shook it in the air. Thought it might be a bad coil so I switched to the 5" and no issues with false chatter. Checked the pin ohm readings and was shocked to find pin 1-2 was .5 ohms, and knowing that seemed to very low for this coil. The 5" coil reads from pin 1-2 is 38.5 ohms. I'd guess something might be wrong. I'll run the detector through my test garden and that will add to my suspensions. I could almost guess someone might have put the wrong coil in the box.
          30 -50 Ohms is a common receive-coil resistance, so even if it's an 11x7 coil for a different First Texas machine, like a F19/Greek series, I would still expect similar R value. The exception would be the Fisher F4 coil, which DOES have a low resistance Receive coil, less than 2 Ohms, I recall. This is made to be compatible with the 'Bounty Hunter' concentric coils that the F2/F4 use.
          I'm not sure about the 'shaking in the air' thing... it could be the ground pickup varying, and a false trigger as a result. My own machine will do that sometimes. Try shaking it horizontally, so it's still the same height above the ground, and all that occurs is shaking, with little pickup changes.
            Did extensive test and found the coil is most likely okay. Noise while shaking the coil only happens when disc is 0. As for the Ohm readings, I think one of my meter leads is failing. Test garden results were good. Thanks for all the input.
