I've recently got a couple of Surf PI boards going and I've wound up a few coils large and small.
My favourite coil so far is an 8 inch flat spiral made with 0.05*50 litz wire. Just a pancake - no basket. Despite a relatively high resistance of around 4 ohm, I'm picking up ridiculously small targets far better than any of my other coils - a strong reaction to 0.05 gram of sterling silver at around 5cm.
What I noticed today however is that within around 30cm of the coil, I can actually hear the coil with my bare ears. The sound is the same frequency as receiving the signals as interference through headphones, however the noise is actually being emitted form the coil itself. It's not loud like an old CRT TV or anything, but it's certainly apparent when the coil is closer to my ears.
..is this normal behaviour? ...Or is this a sign that I've got something set sub-optimally such as my damping resistor? Using the variable resistor circuit I've got it at the upper extreme with no ringing, and I'm contemplating placing higher value R's in the circuit to raise the baseline for further testing.
Could it be an indication that I should be shielding the coil or something? I can't seem to find any reference either on geotech or google to noise being emitted from the coil... Apologies if my google-fu has failed me again
Thanks for any insight!
