Making a Bigfoot?
I put the Excal over a 8" multiturn loop of wire connected to my spectrum analyzer and 3 Khz doesn't show up but 24.56Khz seems a peak. Why doesn't the fundamental show up, I must be doing something wrong?Originally posted by Carl-NC View PostThat looks like an XTerra board, they have a micro embedded. Sov/Excal do not.
Excal is a simple square-wave drive but with a fundamental of 3kHz, so I would expect the critical thing is to keep the TX coil resistance low. There is no resonance cap for TX, and surely not for RX either. Somewhere there is a schematic for the coil PCB.Attached Files
I communicated with Bill Lahr and he suggests a Bigfoot won’t work right with an Excal as it needs a 4 filter detector. Only one half of the coil would detect right. A DD would work though, like the Cleansweep. I have no experience with one. Never seen one taken apart or heard of someone trying to make one.
The "3kHz" frequency you're looking for is actually 3.125kHz, 25kHz divide by 8. Spectrum analysers tend to make a mess of the BBS waveform, the 25k stands out because there is 8 continuous cycles of it, then a gap ( for 1 cycle of 3.125k ) then repeat.
I would say the extra-long DD configuration of "bigfoot" is be easier to design and build, compared to the more exotic figure-8 etc types.
He's partly right, the Bigfoot needs a detector designed to respond in all 4 quadrants. 2-filter vs 4-filter doesn't matter. Most detectors can't do this.Originally posted by bklein View PostI communicated with Bill Lahr and he suggests a Bigfoot won’t work right with an Excal as it needs a 4 filter detector. Only one half of the coil would detect right. A DD would work though, like the Cleansweep. I have no experience with one. Never seen one taken apart or heard of someone trying to make one.
The Cleansweep is just an ordinary DD, except long & rectangular.
https://www.reviewdetector.ru/index....ost&id=4230979
https://www.reviewdetector.ru/index....ost&id=4242998
a pcb of mars coil. has two frequencies. 2 micros = 2 freq-s.
