Hello guys. Just wanna ask if the requirement of my coil resistance is 0.4ohms and i've made it 0.66ohm. Is it still okay? If not,how could i lower down the resistance to 0.4ohms because when i tried to lessen the windings,the inductance is also getting low. What would i do?
0.4ohms to 0.66ohm coil resistance.is it okay?
Thank you bro..what you did is a DD coil bro? Do you have any idea how to make DD coil 18inches in diameter? For minelab gpx5000.Originally posted by alex61 View PostBhathu saaii to explain .I use .2mm strands. I calculate inductance for coil size ,then number of turns then wire length ,then number of strands for .36 ohms allowing for coax and plug resistance so I have .4 ohms at the plug
Do you have any idea where i could watch or view for the diy? Thanks a lot
anyway,may i know the maximum depth of it bro? also the other details like number of turns,no. of wire, resistance, inductance, frequency. thanks a lot bro..you're the answer to my prayerOriginally posted by jinbiao View PostI made 13-inch and 18-inch DD probes for gpx4500, which works well.
