Got some coil shells! wondering about spray 'builders foam' for coil encapsulation??? The expanding, lightweight stuff.....any good?
Coil encapsulation
Thanks chaps, .....this looks like a worthwhile mod to the TGSL coil..... https://youtu.be/XnrStRklcUQ?t=539
not sure the difference in coils at the end will be down to shielding.Originally posted by samsearcher View PostThanks chaps, .....this looks like a worthwhile mod to the TGSL coil..... https://youtu.be/XnrStRklcUQ?t=539
make two coils and they nearly always preform slightly differently
love how he got it to all fit in a slimline box.
Originally posted by Carl-NC View PostWhite's used to use expanding foam for encapsulation. I would be concerned about things moving around as it cures.Foam would reduce coil weight but can have the issue Carl & KingJL stated.Originally posted by KingJL View PostI unsuccessfully tried expanding foam a while back. That was exactly the problem.
This should be an issue if you first use a small amount of epoxy to fix the coil into the housing.
I did this when building a DD coil to ensure the balance didn't move before encapsulation the entire coil. I use just enough epoxy to anchor the coils into position. Then recheck balance.
If balance needed tweaking I could have cut away a little epoxy to move a coil.
correct the screw just flexes the wires slightly. Bit of over kill as you get just as good results by sliding and temporary gluing in place
at the end of the video he depth tests two coils with different shield method's aluminium poor graphite good. I suspect its more to do with the coils than the shield unless they used kitchen foil.
I tried this difference on one coil. Coil unshielded, with thin aluminium kitchen foil and with adhesive copper tape. No difference in possible deepest null, detection depth or shift. Only difference was that unshieded coil detected my hand. Did not tried graphite spray, I use only for shielding plastic enclosures. And I hate itOriginally posted by Koala View Postcorrect the screw just flexes the wires slightly. Bit of over kill as you get just as good results by sliding and temporary gluing in place
thanksOriginally posted by Hyena View PostI tried this difference on one coil. Coil unshielded, with thin aluminium kitchen foil and with adhesive copper tape. No difference in possible deepest null, detection depth or shift. Only difference was that unshieded coil detected my hand. Did not tried graphite spray, I use only for shielding plastic enclosures. And I hate it
