Is there a "better" way to connect ground return paths for separate Tx & Rx coils (PI)
    I may have missed this somewhere in the thread but do you use CAT5 that is stranded or solid?
    Had to go look and the CAT5 I use is stranded wires.
      Less prone to breakage with flexing. That makes sense.
      Cheers
        Thanks Waltr, i was thinking stranded also. Do you guys wind your coil cable around the shaft like vlf, or do you just run it straight up the shaft.
          I wind it around the shaft.
