Nulling Rx is easy. Just connect Rx wires to scope( don't connect Rx coil to circuit, just ONLY to the scope)
Looking at scope for minimum Rx signal(while adjusting Rx coil in coil shell). This is your nulling point. The coils are now balanced. Go and fix Rx coil in place( leaving some small section which overlap the tx unfixed to play with later on)
Now connect rx coil to circuit(remember to have corrected values for capacitor for Rx coil). You should be getting beep with metal targets.
Only now you move on to final stage.
I await your progress.
