Is there a specific way to test a shielded coil should I be hooking up the shield?
The shield should be connected to one of the coil leads. Circuit common if coil is connected a circuit, if exciting resonance with another operating PI(test coil floating)connect shield to one of the test coil leads. I sometimes forget and connect the shield for a floating coil to circuit common. Less effect, not correct.
