I was listening the other day to C-Scope talking about the new Evo-6000. They said they opted for single frequency operation with the coil set for one frequency as it is better as it resonates at it's design frequency, in this case 17khz. They did say there will be option coils to change the frequency higher or lower but this will mean purchasing a new coil to change frequency.
Is this truly the best way to achieve the best sensitivity at a given frequency or are they just holding on to old tech.
There are other makes of detector that you can change frequency with the same coil (Deus, ORX, Kruzer, Anfibio, Nox etc) do these machines have a set resonate frequency matched to the coil which offers best performance and do they lose sensitivity if you change frequency? Or is there a way of making the coil sensitive to a range of frequencies.
Just wondering why they chose to go a different route to others on the frequency selection?
