double D coil for Mirage pi
  • double D coil for Mirage pi
    Hi everybody!
    did anyone built a double d coil for mirage pi? if yes could you please show me how to build it and connect to connector and pcb because i'm beginner at electronic field.
    Sallah
    Originally posted by Sallahkhan View Post
    Hi everybody!
    Sallah
    There is some applicable information in this thread:
    A Dual Field coil would work as well. Here is a link to my YouTube build:
      thanks a lot surfdetector for the informations.
      Q: can i build double d coil at the same way you build dual field?
        They are different coils.
          @Sallahkhan,,,Whch pcb are you connectng it to? The early versions don't have the pcb connectons for a 'DD' Coil. Can you post a pic of your board? Regards, Marty.
            yeah i know that, just what i want to said to connect them in series as you did that's all
              Hi MartyJ1963... it's a new version of Mirage pi made by Elliot called GoldMax i didn't get it yet i'll put it on as soon as i received it.
              Sallah
                Hi Sallahkhan,,,It's ok,,I have already made the Gold-max but I have only used a Mono coil with it so far. The build file supplied to you by Elliot shows you what connections to make if you use a 'DD' coil. You will have to balance the coils (null) and I thnk each coil has its own damping resistor. I'll check my archives to see if I have any other information for you but I also think a 'Dual field' coil (as suggested to you by Surfdetector) will work better with the Gold-max than a balanced 'DD'. You will be able to wire this coil to the 'Mono' terminals of the Gold-max. Regards, Marty.
                  Really! thats sounds good, how did you find it? what's your rating of Gold-max? could i use it to detect mountains and sahara?
                    Hiya Sallankhan. The Gold-max is a very sensisitve detecter. Even with the 3DSS Mono coil it detects very clearly at 12-14 Inches. I have never tried any other coils with it yet though,,I am yet to find time to experiment. I don't know the mineralization of your are but it should be great for sand. Regards, Marty.
                      It's very kind of you to give me informations, thanks for everything Marty. Can i ask last thing, did you make the previous version of Mirage ULTRA MDDSD? if so, could you please share with me the manual if you don't mind?
                      Regards, Sallah
                        @Sallankhan. They were already posted on another thread. The build file is too large to post on here but if you PM me your email address I can send it to you. Regards, Marty.
                          Thank you again Marty your really a helpful man, this is my email: [email protected]
                            Hiya Sallah,,,I have sent you an email with the files attached. Have fun! Regards, Marty
                              Hi Sallah,,Did you get my email? Regards, Marty.
