Sovereign Elite Concentric Coil
  • Sovereign Elite Concentric Coil
    A lot of people say that DD coil used in Minelab detectors have a poor pin-pointing feature. This is normal and there's no solution.
    Before i begin to assemble this coil, i'm asking here if someone have realized a concentric coil TX-(RX + Preamp) usable with this detector.
    If yes, please reply some field test reports.
    DD coil
    hi! you built dd coil for sovereign ?
      a DD coil with different size is not a problem.
      I'll try to build a concentric TX-RX coil but, at this moment, no one have reply to my request for informations.
        Sovereign
        What pre-amplifier you established in the coil?
          I built a concentric for a Minelab Explorer and it worked quite well, though was a bit noisy compared to the DD. Pinpointing was improved as was target seperation in trashy areas.
            Carl did you tried with Al wire instead of Cu
