Hi. I want to build a mono coil with dimensioms 3m x 1m for faster scan. Does anyone has any curves (maybe Eric, Reg or KT315) to see how change the sensitivity between center and the end of the coil because i am afraid that the sensitivity at the end will be poor.
3 to 1 rate coil
The sensitivity will be flat until you get to 0.5m of either end, then it will drop off. So for a 3m x 1m coil, you have a 2m width with a constant detection range. The fall off at the end is similar to that from the centre of a 1m square coil, to the edge. If you want the full 3m scan width, then you want to make a 4m coil.Originally posted by GeoHi. I want to build a mono coil with dimensioms 3m x 1m for faster scan. Does anyone has any curves (maybe Eric, Reg or KT315) to see how change the sensitivity between center and the end of the coil because i am afraid that the sensitivity at the end will be poor.
Eric.
