What about Cat5 cable? This might be ok for the RX but is it thick enough for TX.
Low C shielded cable is tough to find.
Coil Cable Help
Coil Cable Help
Background: I have built a SuperD coil assembly ( TX coil 315uH, 0.6 ohm, 955 KHz SRF; each RX coil 376 uH, 21 ohm, 1.39 MHz SRF ). I am using the coil in conjunction with the moodz alt2h-bridge TX and a fully differential RX (coil fully floating (i.e. no coil connection to GND ), connected to a THAT1512). Initially using NEGLEX 2534 as a coil cable.
The problem: I find that there is WAY, WAY too much capacitive coupling between the conductors (RX to shield 525 pF; RX to TX 1.2 nF). The TX-RX coupling results in an 80 V pulse from the flyback being transferred to the RX input (am using clipper diodes to limit the input to the THAT 1512, and since the result is identical on the + and - THAT inputs, they cancel out differentially). Also the huge capacitance causes the flyback duration to increase from 1 usec to 1.75 usec.
I need to find a more suitable cable for my configuration. I have used Mogami W2947 dual coax S-video cable in the past but the center conductor is too thin for this application (AWG 27... need AWG24 or heavier). So far the best I can find is dual RG-6. I do not like the idea of the solid center conductor as it is a failure point. Also I would prefer to find something with a 5th conductor to use to connect the coil shield. Any suggestions would be much appreciated!
Tags: None
