hello
IDX pro concentric coil with copper foil shield
Use graphite spray ...copper foil is too conductive. It's a metal detector right? Would you expect it to detect a piece of copper foil? .... So why are you wrapping the detector in foil? The foil surface would need to be gapped all over to stop currents flowing due to the magnetic field induced eddy currents ... If you must use copper look up EMI tape not foil.Originally posted by ifrenide View PostSo no problem if I use copper foil instead of graphite spray? the only l problem only when I dont leave a gap, otherwise it is ok to use cooper foil which doesn't expose a problem? am I right?
- Likes 2
Thank you all for your help, I will cut the foil into 4 segments and I will connect each one to ground directly, and see what wil happen, at least I know now that copper foil itself is not a problem, but it must just arranged in a specific configuration to act as a shield. one more thing , I think copper foil conductivity is an advantage compared to graphite spray, and companies prefer graphite spray because it is easy to apply in a big mass production, compared to copper foil which is more difficult to be applied
