Hi all,
I was looking at this industrial metal detector (I assume that it's pulse due to all the rocks) and noticed how thin it was. How are these coils so skinny? I have assumed that the wider the coil, the better as it means that the material is within the field for longer. If the coil is too thin then the return current path affects the magnetic field. Is it possible to make an ultra thin metal detector? How would that manifest in a DIY scenario? Could it be possible to make a single loop coil for a pulse design?
Link:
https://youtu.be/tqrwYeA3jqo?si=GVD4oE0YWOyc20KG
Link:
