Feedback coil on Whites 6000di XMIT coil
  • Feedback coil on Whites 6000di XMIT coil
ID:	428030 Wondered about the size, number of turns, etc. on what's shown as a feedback coil in the XMIT windings on a Whites 6.59khz coil. What's the purpose of the feedback loop in there?. I appreciate any help, or explanation.
    Jim
    It's the bucking coil, used to create an induction balance. Usually wound right on top of the RX coil.
      Thanks, Carl. I figured it had something to with the IB between the coils. So, if I make coils, ala the TM-808, I assume I can leave it out?
      Jim
        explanation you may seek in the patent. US4293816
        if you are not able to seek it on the site (this site) i will help you. anyway first do a click on the huge banner GEOTECH you see above. it is clickable.
        PS. oh not... they had changed the link linked to the banner
          Hi Jim
          If you haven't seen it I suggest you read Carl's article on Coil Basics. Go to geotech1.com, click on Metal Detectors, then Info. "Coil Basics" is there as a pdf document. Lots of helpful information.
          Gwil
            Jim
            Yes, orthogonal coils are balanced by their orientation.
              Yup...should be fairly easy. Probably won't get to it before winter, though. As always, Carl, Thank you
              Jim
                Originally posted by Gwil View Post
                Hi Jim
                Gwil
                Yup, I'll get to that, for sure.
                Jim
