to not to pollute your topic i made one myself:
Making a 15" round coil.
For people without an engineering education, that might as well be in Greek.Originally posted by pito View Postground effect is the only issue im not able the solve = The easiest way is to use quadrature detector, you will have Ux and Uy, you need to rotate both synchronous switching signals until Uy =0 when machine is close to the ground.
Maybe i make mistakes with shielding = good shielding = detector is not responding to human bodies.
bring two hands close to the Rx coil
Jim
So have you checked to be sure the RX coil is not "seeing" the transmit coil? The RX coil has to be in "null" from the TX coil. You may need to tilt the RX coil slightly, up and down, to be sure it's in null.Originally posted by stefan-s View Post
Indeed, that seems to be the problem ad least in my opinion. Depth etc is really good but the ground effect is the only issue im not able the solve probably because of my lake of knowledge of how to building these kind of coils (im have the same issue when i try to build a DD coil). Maybe i make mistakes with shielding or something i don't know i build several new coils but cant get it working properly.
Jim
- Likes 1
Indeed, that seems to be the problem ad least in my opinion. Depth etc is really good but the ground effect is the only issue im not able the solve probably because of my lake of knowledge of how to building these kind of coils (im have the same issue when i try to build a DD coil). Maybe i make mistakes with shielding or something i don't know i build several new coils but cant get it working properly.Originally posted by Jim in Idaho View Post
Will it not ground balance, Stefan?
Jim
Will it not ground balance, Stefan?Originally posted by stefan-s View PostI did this with my spectra v3i but im having lots of trouble with ground effect when i raise and lower the detector im getting signal from the ground.
Jim
LOL...me too !Originally posted by Mark-VA View PostLooking forward to seeing your finished product.
Jim
I didn't know if the spacing was somehow connected to the frequency, so thanks for the explanation. I did know that Fisher had the null adjustment on theirs, but forgive me, I thought it was a pretty crude way to do it...LOL. I think the TF, and TM guys just made the mast so rigid, they figured the coils would stay in null unless treated harshly. So, for me Carl, I'll go with a shorter spacing. I'm looking for shallow mineral veins or float...maybe down to 3-5', not car bodies at 20'...unless they're made of gold, silver, or copper...Ha! As always, I appreciate the input....I might even be getting smarter, or at least, more educated by you guys. Ya know, after thinking about this for a few minutes, I'm thinking a plastic bolt and wingnut, to adjust the RX coil, might be a good idea. Gonna think about that.Originally posted by Carl-NC View PostOrthogonal does not need a feedback coil, however many of them include a way to adjust the tilt of the RX coil which adjusts the null. The TF/TM models don't do this, the null is what it is, and you have to keep the preamp gain low enough to not overload.
Spacing affects depth & sensitivity. Larger spacing will go deeper on the biggest targets but lose sensitivity on smaller targets.
Jim
If done correctly, I'm thinking the Orthogonal configuration shouldn't need a feedback coil. One question I do have is, is the spacing of the coils magnetically, or electrically significant?Originally posted by kt315 View Postfeedback coil. my mistake.
Jim
What, exactly, is a "backing" coil, KT? I did see videos of a guy that converted regular detectors to two-box. He had decent English, but it wasn't his native language. I kinda thought he might be Russian. He does not show any details of what he's doing.Originally posted by kt315 View Posta russian guy did a two-box with the coils in one flatness, unorthogonal. can not give a link, his site had gone.
he used a backing coil between two.
JimLast edited by Jim in Idaho; 09-16-2024, 05:17 PM.
