Hi MD enthusiasts,
These days I make many experiments with using of DD coil for hybrid PI MD. With two pots connected for damping of TX and RX coil respectively, in one strange setting, I meet interesting results. All these experiments are with 15x12" SEF coil from DETECH company. TX coil is 300uH 0.42R and RX coil is 380uH 6.92R. When the value of the damping resistor of the TX coil is unusual low (130R or 62R, TX coil is over over damped), I see the output voltage of the first RX stage with gain of 10. When the damping resistor of the RX coil is set to 47R (very low value), the output voltage of the first stage go near to 0V after only 1us. This allows to recognize 25c USA surely from distance of 30cm instead of only 15cm distance when TX and RX coils are critically damped (with 390R resistor on TX coil and 1K damping resistor on RX coil). The peek TX current is appr. 2.8A. It will be good if someone have possibility to explain this phenomena.
Next comes another bucket of ice-cold water on the head...
