Can I change the coil connector of Pulse Star II Pro?
  • Can I change the coil connector of Pulse Star II Pro?
    Hi everyone,
    I would like to change the coil/charging connector on my Pulse Star II Pro box.
    According to the documentation for the 1m x 1m coil, only pin 1 and pin 3 should be connected.
    Can I safely modify the box to connect only pin 1 and pin 3? Will it work properly with the 1m x 1m frame coil?
    Also, the connector on the Pulse Star II Pro has 5 pins.
    How can I identify which one is pin 1 and which one is pin 3?
    Thanks in advance for your help!
