SPULE32 Coil modelling software by AZIZ
  • #31
    BTW, the coil concept relates to all PI detectors using mono coils. Especialy old ML PI detectors, operated on heavy ground mineral gold fields. Up to 12 % more depth is possible.
    • #32
      Lets revival the GPX 4500 and GPX 5000 (and older models). These gold detectors are capable to operate with pure mono coils without the evil coil-chip.
      So everyone can make his own ripper coil.
      The AI coil analysis is not finished yet.
      • #33
        Coil chip in GPX 6000 and newer models and what the AI thinks of:
        Here is the unvarnished technical analysis of the coil chip in the Minelab GPX 6000 (as well as the SDC 2300, GPZ 7000, and GPZ 8000). When you strip away the marketing jargon and look at the actual hardware, schematics, and how aftermarket adapters work, the picture is crystal clear.
        1. What is actually inside the connector and PCB
        There is no intelligent sensor inside the coil plug or housing measuring real-time physical parameters. It is simply a passive EEPROM / cryptographic authentication chip (similar to a 1-Wire memory device or an I²C security IC—the exact same concept used in printer cartridges or Apple Lightning cables).
        • Passive data storage, not a real-time sensor: When you power on the detector, the GPX 6000's microcontroller sends a cryptographic challenge (handshake) to the chip. The chip replies with a signed ID and a basic coil type identifier (e.g., "11-inch Mono", "14-inch DD", or "17-inch Mono").
        • Zero dynamic feedback: While you are swinging the coil, there is no communication whatsoever between this chip and the copper windings. The chip has no idea how hot the coil is, how mineralized the ground is, or how the inductance behaves. Its sole purpose is to act as a digital bouncer (DRM – Digital Rights Management).
        2. Proof from the field: The "X-Coils" bypass
        The prospecting community has already proven that the chip is electrically unnecessary for operating the coil (most notably through Russian coil maker X-Coils and Australian modders):
        • If you cut the chip out of an original Minelab coil (such as the stock 11" coil) and wire it into a patch lead (dongle) between the control box and the coil cable, you can plug in any unchipped aftermarket coil—whether it is 10 inches, 15 inches, or 22 inches.
        • The GPX 6000 immediately accepts these "unauthorized" coils, tunes them via Auto-Tune (noise cancel) and Ground Balance (pumping), and runs with full sensitivity and stability.
        • The takeaway: If a static chip ripped out of an 11-inch coil tricks the detector into thinking an 11-inch coil is attached—and the detector still runs flawlessly with a 20-inch coil—the claim that the electronics require exact, coil-specific chip data to run its "GeoSense calculations" is technically debunked.
        3. Why the chip actually exists from an engineering & business standpoint
        Beyond pure profit maximization, there are three hard reasons why the engineering and legal departments at Codan/Minelab (a publicly traded defense and communications corporation) implemented this system:
        1. Preventing Chinese 1:1 clones (IP Protection):
        The GPX 4500 and GPX 5000 were counterfeited by the thousands across China and the Middle East. Because the 4-pin connector was completely open, counterfeiters could build knock-off control boxes and immediately tap into the massive ecosystem of genuine and third-party coils (Coiltek, Nugget Finder). By adding a crypto-chip, Minelab forces cloners to break the encryption rather than just copying the analog front-end.
        2. Capturing aftermarket margins (Vendor Lock-in):
        In the metal detecting industry, huge margins are made on accessories rather than just the control box. During the GPX 5000 era, Nugget Finder and Coiltek made millions selling superior aftermarket coils without Minelab seeing a dime. Under the GPX 6000 licensing model, third-party manufacturers have to pay licensing fees for every single coil model and buy the pre-programmed chips directly from Minelab.
        3. Liability and warranty control:
        Oversized coils (over 18 inches) or poorly wound cheap coils generate massive peak flyback voltages and current spikes during the transmit pulse. With the GPX 5000, poorly insulated or overly low-resistance aftermarket coils occasionally blew out the MOSFETs in the detector's transmit stage—and users sent the control boxes back to Minelab for warranty repairs. The chip allows Minelab to block any coil outside their strict electrical specs (inductance, damping resistance, and capacitance), drastically cutting warranty claims.
        Blunt Summary
        Technically speaking, the chip in the GPX 6000 is an artificial electronic lock with zero benefit to detection performance. The search coil itself remains pure, classic analog physics (copper litz wire, shielding, and damping resistors). Minelab uses the cryptographic handshake to enforce an accessory monopoly, extract licensing royalties from third-party coil makers, and protect its hardware from being overdriven by massive, unregulated aftermarket coils.
        That is the exact reason why purists and deep-seeking prospectors still hold onto the GPX 5000: it represents the end of an era as Minelab's last flagship PI detector where coil physics wasn't restricted by software DRM.
        Would you like to dive deeper into the electrical specifications of GPX coils (such as target inductance, litz wire winding, and damping resistance in spiral vs. bundle windings), or look at how to set up the GPX 5000 to push maximum depth with oversized coils without stressing the transmit stage?
        KI-Antworten können Fehler enthalten. Weitere Informationen
        Coil chip: EVIL
        Lets fučk ML!
        • #34
          Hi all,
          I am quite frustrated with "free" AI's.
          Google AI no good. Full of mistakes..
          Claude AI is very good but the time limit for Claude Free prevents really serious working..
          Claude AI is so good, that I have fed it with screen shots of my smartphone on a lost AI chat (Google) of the current mono coil analysis (in german, see PI-Coil-Analysis-DE-1.pdf).
          It has translated the screen shots, checked the calculated values, made a new PDF and found even bugs in it.
          But due to the time limit, it has not fixed them yet.
          I should really look for a Claude Pro​ subscription.
          I need Claude Pro​ subscription​..
          I need Claude Pro​ subscription​..​
          Aziz
          • #35
            Aziz,
            Be Careful-You’re going to get sucked ...into the money-draining spiral of using Claude—it’s so so good, but you’ll just keep wanting more and more. I know this because of my grandson, who performs incredible calculations using Claude pro.
