Hi, i would like to see if some other experiences with unbalanced coils..?
When making coil, everybody trying to gain as better balance as possible...which is quite normal.....
But experimenting with Classic 3 i made several different coils, few of them unbalanced and working very good.
Classic 3 by its conception is pretty simple device. Discrimination level is tuned with one pot. It is subjective, from case to case, at which level it will discriminate certain type of metal...I do not mind to know exactly what i detected with CL3...but to know accuratelly is it iron or "coloured" metal like bronze,brass,al,ag,au or cu....Since i already do know character and preferences of terrain, i only need that kind of simple discrimination....Therefore i noticed that slice unbalanced coil can go even deeper in some cases than balanced??? Stabillity can be gained through adjustments....
When i said "unbalanced", i ment one or less of windings of FB gives stronger TX field, but not so strong to "choke" RX...yet giving louder "echo" from detected object....
Am i right? Is it right way of thinking? This could not be taken generally....just in case when simple device is needed...
Any comments?
regards!
Carl is there any way to fix problems with this forum.....i have problems last few days....you already gave explanation but still problems!?
