This might be an old idea but anyhow, to stiffening and waterproof the coils
when fitted in the housing you could buy some PU foam and fill the housing.
Remember that of you do you need two holes one as filling hole the other as expansion hole,
this material expands as it hardens so an idea not to blow the housing is to clamp the entire coil house.
I have tested it and makes the coils to be in exact place and the slight flexing dissapered.
However it takes some skills to make it good so some experimenting are needed.
