10'' DD Coil construction for Gold Bug 2 help!!!
  • 10'' DD Coil construction for Gold Bug 2 help!!!
    Hi ALL,
    I would like to realize a coil 10 '' DD for my fisher gol bub 2!
    It is possible? Help, please!!!
    Porfirio from Rome,Italy.
    Hi all,
    I have measured the two resistances of my coil (10 xes 5 elliptic coil),
    these are the measures of the two resistances of the coil:
    Pin4 (+ white) to Pin5 (- mass) is 19.9 ohms
    Pin2 (+ red) to Pin3 (- mass screening) is 2.6 ohms
    Pin5 without connections.
    I hope to one help of yours!
    Porfirio
      DD coils
      pin2 and pin3 will be Tx coil it must be
      about 30-50 turns diam 0.55 0.6mm
      /for DD 10 inch diam must to be about 7.5inch circle/
      pin4 and 5 must to be Rx coil diam 0.2-0.3mm turns 120-150turns it is no so critic...
      pin 5 shield of Rx coil or Rx i Tx coils... u must to see when connect the shield ....
      Porfirio[/quote]
