There is much to read here on this forum so thought this also would be a good place to find further info regarding inductance differences for coils produced for Minelab Pis and following the recent discussion "need help reading inductance."
I had read of differences regarding lower inductance readings between newer and older coils produced by CT and NF for use on ML detectors. The uH readings on the newer mono coils now range from a low of 226uH to 256uH while the older coils came in at 300-310uH.
Some of what has been posted here on this forum says the Minelab GP series detector coils need to have the ohms right at 0.4 with an inductance of 300 uH (microhenries) The inductance is fairly critical as ML machine don't like if the value deviates too much from 300uh and if trying to make a coil for the ML the key is to get both the resistance and inductance as close to the manufacturer's coil as possible. You will find that for a specific size coil there is only one wire size that will get you to that resistance and inductance. ML uses a front end that differs noticeably from other pi detectors so you will have to carefully “fit” the coil to the design.
I own both CT and NF coils for use on both my SD2000 and GP3000 and after reading the above as well as the inductance differences between the newer and older coils which seem to deviate from 300uh by a fair amount I therefore wish to ask the following question.
What should I expect to encounter using a newer lower inductance coil on either of my ML detectors.?
Thanks for your answers,
Gary
Gary
Regards IBGold.
