Carl,
The problem I have been running into is the coils I reproduce are either a exact match with Heneries, but low with resistance or exact match with resistance and low with Heneries. The Rx coil has no components with it, just the coil. Tx has coil, parallel resistance and capacitance. How would you go about adjusting the reproduced coils to match? I have study the L network which is close to what is needed. The Chebyshev networks. This one is way to much for what is needed, but has nice tables that you plug in numbers for the resonance and frequency wanted. Main question in the design of the coil(s) do you make them below the measured coil, then add components to match or do you look at it from another direction? I have tried using the scope and matching the frequency and resonance, but there is alot of trial and error in this process. I would like to get closer with math than guessing with components. I have read that capacitance is the way to go for resonance,frequency and impedance matching. Any help would be appreciated. Rick S
