Carl,
It seems that I am the only one right now that is doing anything on the this forum. I would hope others would join in on the fun.
I have built two DD coils and this is the result of what happened when I hook them up. I found out that one coil is on the positive side and will not balance with ground. The other one is negitive and will not balance to ground. I have tried different capacitance in parallel to see what the difference would be in getting the coils to react correctly in the DD confriguration. I haven't gone over the 50khz limit from the transmitter, but have tried from about 47 to 50khz. I still can't get the DD to work right. I have tried bending the Rx coil over the Tx coil and just laying the Rx coil on top at the proper spacing. Still no control over the ground balancing. Would this make any difference balancing of what plane the fields would be in? I have checked and rechecked the inductance of the two coils. I have put them right on the money each time. I thought that if there is error in the inductance meter I would make adjustments for that which I have done. When I pass my hand over the coil there is to much response as compaired with the stock coil. What I have basically is two Lc circuits and the only thing I haven't really played with alot is the resistance. I have tried a resistor in series and I still don't get any ground balance. I have looked at the impedance, Q, and bandwidth. Any hints would be helpful. Thanks for the bent ear Carl. Thanks, Rick S
