Originally posted by simonbaker
You are right, the balance of the concentric, co-planar IB coil, is less sensitive to imperfection, than on the DD coil.
There are some parts where my understanding is still a bit vague. For example, the incidence of the 2 opposing fields TX and BU, on a large thin target, like a piece of alu foil, shows a predictable inverse response. I mean to say, that at a certain position within the coil field, the foil produces a negative response, while at a different place the response is positive.
This confirms your statement above.
However, a thick piece of alu plate of the same surface dimension, gives a positive response everywhere. This must have something to do with the deeper eddy currents, while the inverse response if from the skin eddy currents.
But why is that?
It is important to find the answer to this question, because this phase inversion is a problem with discriminating thin, rusty, steel fragments, like remains of sardine cans etc. that litter productive detecting sites.
Maybe I should clarify, that I used a TX pulse specially designed to enhance deep eddy currents, from massive targets, when I came across the problem described above.
Monolith
-- maybe moodz can get one to work well.
