...I've searched the forum and haven't been able to find a reference to these questions.
From the flux plots Aziz has provided on several posts, it seems to me that coils of most (all?) types are fairly insensitive in a horizontal plane, i.e.- the coil really doesn't care about what is beside it as long as the object isn't below or above the coil, given a reasonably small mass and conductivity/eddy currents.
Question 1- Is this assumption correct?
Question 2- If the above assumption is correct, would it be a reasonable experiment for me to move part of my HH circuit (Q1 to the input of R23 or Q1 to TP3, Rev D1, DDcoil) to a small faraday shielded cage just off the side of the coil? (After succesful no-mod testing, of course).
Question 3- Would such a move in circuitry help to minimize the Q1 capacitance delays from the cable while (if possible) also minimizing the noise picked up on the return cable to the first stage amp, IC6?
I realize that there are several signals/pwr connections to route and that switching coils might require some re-adjustment, but I thought that I might pick up enough of an advantage in capacitance delay and noise to be worth it on the very short sample times needed for small gold nuggies.
Any thoughts on this or am I way off base? GTB
Dumb me.
