coil method for bifilar coil
  • coil method for bifilar coil
    coils.....
    i found in my local emporium a collection of "hook up" wire
    plasic coated
    .5 mm center solid conductor
    and gives about 1R per 6 meter lenth
    this is nice for a bifilar coil
    as the shop had several colours
    i will set too work today to build a mak 2 multicoil set
    from this and some cloth tape {normaly for heating insulation or for platerboard walls}
    i used the approch with the last bifilar coil {very precice for bfo detector arrangement will double there sensativity and output and you can also make the coil directional depending on the twist direction and the winding order
    i use a pre resistance measured wire 23R for triangle coil
    or pi X pi a s a size in inches 9 " being the first overtone of pi 3.14 etc
    so using a drill set to the direction i want to wind first
    run off the run of bifilar from your two wires ....using the drill
    then coil this
    you can also add center tap etc
    i tried this using the terrazo tap coil fet oscilator design and was able to increase its field by around 30% by replacing the tap coil with a bifilar tap
    Re: coil method for bifilar coil
    http://www.emclab.umr.edu/new-induct/
    here is a coil calculator i use for large coils of different shapes
    emclab
