Thought I would share a pic of internals of a 15X12 Sovereign DD coil I have been working on. I have built quite a few DD coils for my Sovereign GT. This configuration seems about the best. Larger coils I have tried were only more cumbersome and performance decreased. Finished she'll weight in at just under 16 ounces with a bottom bonded on. I use a little extra plastic in between the windings for support and to attach the bottom scuff plate.
Homemade Sovereign Coil
This topic is closed.
Hi Simonbaker,
I twist several same gauge wires together to mimic litz wire. The small circuit board is a pre-amp necessary for any sovereign coil to work. It is similar to the factory pre-amp. As far as testing all I will say I will never go back to a stock coil again.
kt315,
Don't understand you questions.
Sorry
I do not see usefull information from you. yep the photo is wonderfull but you do not give details of tuning and schematics.Originally posted by plumabob View Postkt315,
Sorry
so I also do not undestand these are FREE info or Top Secret.
be objective. give ALL DATA if you REALLY want share out your info.
SORRY FOR BAD ENGLISH!
There is plenty of info on this forum about tuning coils if you look around. I have no schematics for anything. I'm basically a seat of your pants guy. I just jump in and play around until I get it to work. Again sorry but I can not help you.
Originally posted by plumabob View PostThere is plenty of info on this forum about tuning coils if you look around. I have no schematics for anything. I'm basically a seat of your pants guy. I just jump in and play around until I get it to work. Again sorry but I can not help you.
How about this? :
What componenst comprise the pre amp circuit?
How many turns of wire are you using?
Thanks for posting that ivconic. That is the original sovereign pre-amp. There have been some changes since that design was used, but it still works just fine.
As far as turns. It does change depending on coil size and I don't count. I believe TX is about 40 and your RX is about 25. When I build a coil I over wind then remove turns while checking inductance and resistance until I'm near factory specs. Hope that helps you.
Amazing that power is stolen from the TX coil to power the preamp. You'd think that would limit the Q of the coil. Maybe it's insignificant, but....Originally posted by ivconic View Post...
Thoughts Aziz?
I guess proof is in the pudding, it's a successful design. Alternative would be to run a power wire in the cable, why not?
-SB
