Can anyone tell me which pins on the Whites 15" round coil are for transmit- recieve & shield.
Whites 15" coil info
White's TDI 5 pin connector with standard 12 inch coil
I would like to do a continuity test to determine if any breaks or damage exists in the search coil assembly. My understanding is that it is a dual field coil;therefore:
Should pin 1 only show continuity to pin 2?
Should pin 4 only show continuity to pin 5?
Thanks, Mike.
