Garrett GTI 2500 coil wiring
  • Garrett GTI 2500 coil wiring
    Greetings to all of you,
    I have to rewire a Garrett coil (plug with 7 pins).
    I have a new plug for replacement,
    but the original one is a moulded one and damaged,
    a little bit difficult to be sure of the good colored wire affected to the good pin number.
    I can properly do the fix but no information
    If anybody can tell me ?...
    Many thanks in advance
    Kaern,
    The GTI cable has three separate coax, outer jackets red, white and blue and a green single conductor
    Pin 1 -Blue Shield, Red Shield plus jumper to Pin 7
    Pin 2 -Red Center
    Pin 3 -Green
    Pin 4 -White Center
    Pin 5 -White Shield
    Pin 6 -Blue Center
    Pin 7 -jumper to pin 1
    Hope this helps
    mark
      Hi Altra !
      many thanks for your quick reply,
      now I can do my job.
      if I can help you anytime )
