What would be the out come by winding a
  • What would be the out come by winding a
    PI mono coil with 26-30 awg enamel coated magnetic wire.
    It would have a little higher series resistance.
      Also using enameled wire will give you higher parasitic capacitance which produces a slower coil if it is for a PI.
        Hi All,
        To lower paracitic capacitance use a spacer between the windings and between the rows, a similar diameter chord for the windings and a sheet between rows, what you would be trying to do is emulate the windings as if you were using an insulated wire ie: "distance equals less capacitance".
        Regards Ron
