Originally posted by DOOLEY
View Post
I was kind of hoping you would come back with a partial scat or maybe a url... or think of something you left out of your description because that sounds like a bizarre contraption.
Then, it occurs to me that if your description was accurate, 7.7% duty cycle with a 10.5 cps signal is almost 4 milliseconds.
That is a tremendously long pulse-width.
Perhaps what is being done is processing the return signal during the ramp-up.
With such a long on-time, they would necessarily be using a coil with very (very) large inductance. Just a guess.
I was looking for some piece of the puzzle to express to you that it is NOT a high voltage that illuminates the target, but instead the current, by producing a changing magnetic field is what illuminates the target. The resultant voltage is relatively consequential.
Case in point, your walk-through detector, or is it just too far off the beaten path?
As an after-thought, safety probably would be an issue for a security scanner, or at least I hope it would be.
